Re: Re: ONE WIRE ALTERNATOR - Battery Drain Down
Posted by Bus Driver on April 08, 2003 at 05:51:59 from (65.165.153.12):
In Reply to: Re: ONE WIRE ALTERNATOR - Battery Drain Down posted by Jailkeeper on April 07, 2003 at 20:25:54:
The test procedure suggested by jailkeeper is the one that I would use. But some discharging currents may be less than required to light the test lamp. For that reason, I use a voltmeter instead of the lamp. A 1 volt draw will drain a battery over a few days. When the "leak" is disconnected, the voltmeter reading will drop to zero. On one of my tractors, the problem was wet dust on top of the battery providing a current path from one post to the other.
Post A Followup
: Re: Re: Re: ONE WIRE ALTERNATOR - Battery Drain Down
