Farmall Tractors Discussion Board |
Re: int 350 utility, good machine?
Posted by Farm-Al on September 12, 1999 at 07:41:06 from (152.163.204.30):
In Reply to: int 350 utility, good machine? posted by greg m on September 11, 1999 at 20:03:56:
Greg M. All the the 350's I was ever around did have a live PTO. We only sold one 350 Diesel in the shop I worked at and I belive the engine was a Continental Diesel which I don't remember much about. The butterfly in the injection pump is a good question, the only thing that comes to mind is the setup Perkins used on some of their engines. They had a butterfly [like a throttle plate in a carb] in the intake manifold and used the differential pressures to control the injection pump operation. If this one is missing I would wonder where it went if infact it was in the manifold. Should be someone out there that knows for sure about this setup.
Post a Followup
