Re: International Harvester 884
Posted by karl f on April 08, 2003 at 18:18:58 from (65.237.15.161):
In Reply to: International Harvester 884 posted by Jim on April 08, 2003 at 17:51:22:
try your local case/ih dealer, if nothing else they can direct you somewhere that supplies them. this tractor was built around the time ROPS was first becoming standard issue on some makes/models, so there probably is one available.
DO NOT PUT A SEATBELT ON without a ROPS!!!!
in the meantime, keep a level head, and stay on level ground at safe speeds.
good luck
-karl
Post A Followup
: Re: Re: International Harvester 884
