Re: H-FARMALL OIL PRESSURE ADJ.
Posted by Steven@nd on April 09, 2003 at 06:20:37 from (12.23.184.244):
In Reply to: H-FARMALL OIL PRESSURE ADJ. posted by gary on April 09, 2003 at 04:52:09:
First, how much oil pressure to you have? Anywhere from 15 lbs to 75 lbs is perfectly acceptable.
Adjusting the oil pressure can be done by rebuilding the oil pump, new relief valve spring, or new rod, main, and cam bearings.
Post A Followup
: Re: Re: H-FARMALL OIL PRESSURE ADJ.
