Re: H-FARMALL OIL PRESSURE ADJ.
Posted by Aces on April 09, 2003 at 08:33:35 from (205.186.122.155):
In Reply to: H-FARMALL OIL PRESSURE ADJ. posted by gary on April 09, 2003 at 04:52:09:
Sreven is right but 15PSI a little light, you can rebuild the pump, the drive shaft is the one thing the gets bad. A weak spring would cause low pressure. any time I rebuilt a pump for an H or M
I pluged the relif hole so the relief valve had nothing to do with pressure to put out has much pressure never had one fail out of hundreds not blown gaskets.My 2 cents
Post A Followup
: Re: Re: H-FARMALL OIL PRESSURE ADJ.
