Re: Farmall A cooling system
Posted by Tom of MN on April 09, 2003 at 19:53:22 from (65.45.140.205):
In Reply to: Farmall A cooling system posted by Joe WA on April 09, 2003 at 19:19:53:
Joe,
I've owned a Farmall B for about 30 years now. It does the same thing. They have the same engine and cooling system. Neither has a water pump, so convection currents carry the coolant through the engine, into the radiator and back into the engine. When you shut them down after working them a bit, the coolant tends to gurgle in the engine. My temperature gauge never rises and the radiator never boils, so I assume it's a natural phenomenon in an engine without a water pump.
Post A Followup
: Re: Re: Farmall A cooling system
