Re: Re: got my new M home...
Posted by IRONHEAD on April 10, 2003 at 10:55:19 from (156.63.133.8):
In Reply to: Re: got my new M home... posted by Bob M on April 10, 2003 at 07:16:35:
THANKS BOB. ILL TRY ADJUSTING THE BELT TONIGHT. AS FAR AS THE FRONT END GOES, IS IT FAIRLY EASY AND CHEAP TO SWAP TO A WIDE ? THANKS AGAIN CHAD
Post A Followup
: Re: Re: Re: got my new M home...
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
