Posted by Janicholson on March 29, 2009 at 15:30:48 from (64.83.193.190):
In Reply to: 1950 cub re-wire posted by walterd on March 29, 2009 at 15:14:27:
The magneto is not at all connected to the other parts of the electrical system. It gets no voltage at all. A single wire from the side of the mag goes to the Push Pull switch. This switch is a grounded body switch. Thus the switch grounds the mag, shutting off the tractor. A ll other parts of Bob's diagram will work. Lights and starter, and charging system. Use a combination of #2 and #4 diagrams. At the amp meter there may be a wire connected directly to the fuse this will replace the wire from the L terminal on the VR (some had no L terminal and were wired that way). There will be no wire going to the ignition sw, as on yours it has no wire to supply it. Note in #4 the only part you need is the Mag wiring. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
