Re: H-FARMALL OIL PRESSURE ADJ.
Posted by Sid on April 10, 2003 at 17:58:06 from (206.158.165.178):
In Reply to: H-FARMALL OIL PRESSURE ADJ. posted by gary on April 09, 2003 at 04:52:09:
If your H has low oil pressure I'd remove the oil pan. There is a screen to keep large debris from getting into the oil pump. The tube and screen come off easy and you can't miss it. When I rebuilt my H the screen was about half plugged up. I'd start with that as well as a fresh filter with some new 30 weight oil.
P.S. I think there is one long bolt towards the back of the pan and one stud. It may be a good idea to note where it went to avoid breaking it off in a shallow tapped hole.
Post A Followup
: Re: Re: H-FARMALL OIL PRESSURE ADJ.
