Re: H Farmall W/Front on Full Steel
Posted by Bill Smith on April 10, 2003 at 20:33:21 from (63.147.130.128):
In Reply to: H Farmall W/Front on Full Steel posted by Jimmy Renner on April 10, 2003 at 11:31:02:
Seems as if I seen a picture of one somewhere on this site. I myself have a tricycle H on full steel. The front steel wheel's are enter-changeable with factory rubber tired wheel's. As long as you got a factory wide front and front steel wheel's you could assemble it the way you want useing whatever wheel's. Odds are, you will have better luck finding the wheel's and the wide front seperately. Then put it together yourself. You might end up with extra tractor, but you could always sell the narrow front, rubber tired H later. In my area, an H that runs and has useable tires is worth around the $700 range. I have a complete set of steel wheel's that I consider worth about the same amount as you would have invested in new tires. Not sure what those wide fronts are worth.
Post A Followup
: Re: Re: H Farmall W/Front on Full Steel
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
