Re: Super A Cluch Problem!!!!!
Posted by Hugh MacKay on April 11, 2003 at 02:53:51 from (216.208.58.190):
In Reply to: Super A Cluch Problem!!!!! posted by Jarrett Broadwell on April 10, 2003 at 20:01:45:
Jarret: Been there and done that, I think you have the clutch disc in backwards. I once had some friends show up, just as was at point of separating tractor at clutch housing. Rolled it apart, unbolted old presure plate, laid old clutch disc on blocking holding up rear section of tractor, so I would remember which way it when in. I went out to my pickup to get new parts, when I returned one of my buddies had clutch disc in hand. He was I must admit a retired agricultural engineer, traimed in the 50s and tractor was Farmall 130. To make long story short 1.5 hours and tractor was back together. Clutch adjustment on my tractor that afternoon was exactly as you describe. Later that day I split tractor again just to turn the clutch disc over. I had probably changed 10 Farmall clutches prior to that in lifetime with no problems. There is something to be said for taking time to look things over a bit when doing these jobs,
Post A Followup
: Re: Re: Super A Cluch Problem!!!!!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
