Re: what oil do you use
Posted by Dave_Id on April 12, 2003 at 06:32:02 from (67.250.102.170):
In Reply to: what oil do you use posted by D.W. on April 11, 2003 at 18:17:31:
If the service book says use HiTran, then by all means, use HiTrans. You have no idea how the tractor was used before you got it, but those gears won't wear out again in your lifetime.
Post A Followup
: Re: Re: what oil do you use
