H steering u-joint
Posted by williamf on April 12, 2003 at 09:01:38 from (66.82.9.44):
third party image
The u-joint on my H is worn out. Loose, rattles. PO had welded the ends of the spider to the yokes. A while back I ordered a new spider and the yoke that attaches to the worm gear shaft (the part on the right). What came, and I'm sure it's an upgrade, is in the lower picture. It wouldn't match up with the old yoke on the steering wheel shaft even if that weren't ruined by the weld and the hole's being all wallowed out. My plan is to order another yoke like the new one I've got. I'll cut the old yoke off the steering wheel shaft and grind a slot for the woodruff key. It looks to me like it'll fit together like that, but I thought to check with y'all for warnings or better ideas. Thanks
Wm
Post A Followup
: Re: H steering u-joint
