Re: Replacing the seal on the H brake shaft
Posted by Tom on April 13, 2003 at 03:44:42 from (198.108.134.93):
In Reply to: Replacing the seal on the H brake shaft posted by mike in PA on April 12, 2003 at 21:19:28:
Mike, The bearing assembly with five bolts does not come off. You have to dig the old seal out being careful not to damage the seal surface on the axle. I recommend replacing the one seal with two seals back to back because the old seal may have worn a grove in the axle from many years of service. The second seal you install may find virgin surface and prevent oil leakage. If this doesn't work, there is a thin sleeve available that installs on the axle providing a new surface for the seal to wear. Tom
Post A Followup
: Re: Re: Replacing the seal on the H brake shaft
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
