Re: 6 volt / 12 volt generator?
Posted by steve on April 13, 2003 at 15:51:16 from (204.246.222.27):
In Reply to: 6 volt / 12 volt generator? posted by Dan on April 13, 2003 at 09:19:51:
there are two terminals on the generator, F and A. Ground the F to the case with a jumper wire. start tractor and measure the voltage across the A to F terminals. a 6 volt system will put out 10-15 volts without a regulator. A 12 volt system will put out 18-30 volts without a regulator. As you can see, you could use a 6 volt generator to charge a 12 volt battery if you get the right regulator.
Post A Followup
: Re: Re: 6 volt / 12 volt generator?
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
