Re: Negative vs Positive ground on 12 volt conversions
Posted by Bob M on April 13, 2003 at 15:59:41 from (66.66.123.133):
In Reply to: Negative vs Positive ground on 12 volt conversions posted by Dennis on April 13, 2003 at 12:49:19:
Dennis - As the others mention, all production alternators and about 99.9% of the aftermarket alternators are negative ground!
Best way to tell what you've got is with a voltmeter. With the battery connected and the engine stopped, measure the voltage between the alternator "BAT" terminal and ground. (Put the red wire from the meter on "BAT"...) If the meter reads +12 volts or so, your system is negative ground. Conversely a reading of -12 volts means positive ground.
Your non-functioning ammeter could be either a bad ammeter (needle's stuck) or the ammeter is wired up wrong.
Hope this helps!
Post A Followup
: Re: Re: Negative vs Positive ground on 12 volt conversions
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
