Re: how much would things weigh?
Posted by Randy in NE on April 14, 2003 at 04:14:23 from (216.58.237.20):
In Reply to: how much would things weigh? posted by Bryce Andreasen (Magnum) on April 13, 2003 at 19:45:49:
For the 7500 lb class you will need to weigh 7500 lbs or less with you sitting on the tractor. I would guess that the split weights are in the 140-150 lb range. The fluid in the tires is going to weigh about 8 lbs/gal. I would drain/pump the fluid out of the tires and then re-weigh.
Post A Followup
: Re: Re: how much would things weigh?
