Re: IH Cub 12v conversion
Posted by Bus Driver on April 14, 2003 at 17:51:27 from (65.165.153.164):
In Reply to: IH Cub 12v conversion posted by Pat on April 14, 2003 at 09:31:46:
On the relatively few Cubs which were equipped with alternators from the factory, the resistor used was 25 ohm. I have used them up to 44 ohm with good results. The lamp has over 50 ohms resistance and provides adequate exciting for the alternator. I use 5 watt wirewound resistor. The resistor is the most durable device of the 3 possibilities.
Post A Followup
: Re: Re: IH Cub 12v conversion
