Re: Farmall H gauges
Posted by Larry in CO on April 15, 2003 at 18:36:56 from (32.97.110.142):
In Reply to: Farmall H gauges posted by John on April 15, 2003 at 18:31:20:
John, Sounds to me like you have great oil pressure. Wouldn't worry at all 'bout that. As far as the temperature goes, all seems normal. The temp will go up in almost any engine after you shut it off. This is due to the coolant not being circulated thru the radiator any more. It will continue to gain heat from the motor for a bit, then will start to drop. HTH Larry
Post A Followup
: Re: Re: Farmall H gauges
