Farmall Tractors Discussion Board
Re: Any tips on installing new rod end and main bearings on a Farmall B?
Posted by Farm-Al on September 12, 1999 at 20:37:01 from (152.163.195.186):
In Reply to: Any tips on installing new rod end and main bearings on a Farmall B? posted by Mark on September 12, 1999 at 10:18:13:
Mark Itf in in pretty well covered it however I would add one caution on using plastigage when checking main bearing clearance, when you tighten up a main cap with the plastigage on the bearing shell the weight of the crank can give you a false reading, I always put a jack under the crank and put enough up pressure on it so it's tight against the upper shell. Good Luck!
Post a Followup
: Re: Re: Any tips on installing new rod end and main bearings on a Farmall B?
