Re: Water Pump Leak on H
Posted by The Red on April 16, 2003 at 09:29:18 from (206.246.187.2):
In Reply to: Water Pump Leak on H posted by Farmall Ed on April 16, 2003 at 05:16:10:
Any IH dealer should beable to get you the 2 seals, 2 bearings and packing so you can rebuild. Get at least 2 packages of packing. One is usually not enough.
One tip for your. When you get ready to install the new bearings, pack them in grease first. It will take a lot less pumping on the fittings. DON'T pump the front fitting until you have the fan blades installed. That front seal will pop out on you. Wonder how I know that??? :)
Post A Followup
: Re: Re: Water Pump Leak on H
