Re: Re: Re: Re: Re: Re: Super-A transmission capacity
Posted by gene b on April 16, 2003 at 13:03:24 from (12.212.25.99):
In Reply to: Re: Re: Re: Re: Re: Super-A transmission capacity posted by Hugh MacKay on April 15, 2003 at 10:03:59:
No as the plate that blocks off the area where the pulley assy would cover up this passage. If i am going to use a belley mower i will take the assy paart as lots of times found the passage either blocked or partially plugged and with the pulley on the mower running under load good lubrication is important. In our area the belt pulleys were used as a lot of feed was ground.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Super-A transmission capacity
