Farmall Tractors Discussion Board
Re: Water in Oil After Overhaul
Posted by Curt Cooke on September 13, 1999 at 05:52:19 from (207.75.224.250):
In Reply to: Water in Oil After Overhaul posted by Bill(Tx) on September 12, 1999 at 18:48:55:
I don't think you should be concerned about a few ounces of water in the oil as far as engine damage is concerned. First of all 6 oz. is not much and water is slippery too. Heli-coil will work and there's really nothing to it. I would replace the head gasket with a new one, from the dealer if possible. I've had aftermarket head gaskets that just didn't work no matter what. Also be sure all threads of studs or bolts are lubricated and clean before torqueing; be sure the torque applied is stretching the stud and not just overcoming friction in the threads. Cheer up.
Post a Followup
: Re: Re: Water in Oil After Overhaul
