Re: Re: Re: Re: Re: Re: Rebuilding Farmall M
Posted by jakee on April 17, 2003 at 18:33:08 from (152.163.189.203):
In Reply to: Re: Re: Re: Re: Re: Rebuilding Farmall M posted by Erik Mything on April 17, 2003 at 16:41:32:
if you put the head on without the gasket and rollthe piston,s to top dead center one at a time and the piston does not touch in the quench area, you , will be fine because most of those gasket,s wii be at least .085 thick after compresed.the quech area is the part of the head that is flat next to the combustion chamber,what you must do is look close at about 3 diffrent spot,s were the piston comes close to the gasket wen it passes it on it,s way up and past it ,i trimed the edges of the pistons.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Rebuilding Farmall M
