Re: IH 966 with Squealing Hydraulics
Posted by RAS on April 17, 2003 at 22:24:17 from (66.87.12.37):
In Reply to: IH 966 with Squealing Hydraulics posted by David Kendall on April 17, 2003 at 21:01:18:
The pump for the steering is bolts to the MCV. This is the valve on the left side under the battery box. First thing I would do is change the filter, then if no change replace the power steering relief valve. It is behind a plug in the bottom of the MCV.
The pump for the hitch and remotes is on the left side of the tractor under your left foot. The first thing I would do is change the couplers on the hoses going to the tractor. With time they will wear and not open all the way and cause the flow to slow down and cause the pump to go on high pressure when you use the remotes, this would cause the squealing noise.
Post A Followup
: Re: Re: IH 966 with Squealing Hydraulics
