Re: Lift All Leaks
Posted by Delbert on April 18, 2003 at 15:16:27 from (63.77.102.186):
In Reply to: Lift All Leaks posted by Rick Barton on April 18, 2003 at 14:52:31:
A seal on back of pump needs to be replaced where it hooks up to drive shaft. They are heavy close to 100#. Two people can easly handle it put a bar through the bottom of the pump take out bolts and lower it down. Hope this helps good luck.
Post A Followup
: Re: Re: Lift All Leaks
