Re: What is the PTO Speed of a '43 Model H
Posted by F20II on April 19, 2003 at 09:35:19 from (208.187.159.196):
In Reply to: What is the PTO Speed of a '43 Model H posted by Aaron Veale on April 19, 2003 at 08:05:11:
The power take-off speed fro an H is 540 r.p.m. the belt pully speed is 1,019, the belt speed with a 9 1/2 inch diameter pulley is 2,601 feet per minute. This per the IH "H" manuel. There are different size pully's that can be used to get better spped or less, not to long ago on this Form I believe someone gave out the formla. You might do a search of this site using the the words "belt pulley ", I did see it in the manuel but I only did a quick run though trying to jogmy memory cells. I have also seen someplace a belly mower on an "H" but can't remember were, I have a cycle bar mower on mine for cutting hay. Most people like to use an "A" , "B" , along with Cub's for cutting grass, in some case's people with large acrage lwans use "C". I gues in what you have or what you need to fit the purpose of what your doing with what you have :o) Good luck hope this helps :o)
Post A Followup
: Re: Re: What is the PTO Speed of a '43 Model H
