Re: Hydraulic connections
Posted by Gary-Miss on April 19, 2003 at 14:42:52 from (64.12.97.13):
In Reply to: Hydraulic connections posted by Bart on April 19, 2003 at 03:38:58:
Your LIFTALL on your tractor,according to theIH service manual GSS-5034, has a max pressure of 800 psi )This is the late model,early models kicked off at 450 to 500 lbs). There's a good bit o reading on the four positions of the valve. It will work for a front end loader and you can even set it to feed a remote open center spool valve or a manifold of valves so you can operate multiples of single action or double action cylinders according to the book and, this isprobably what I would suggest (feeding off the right outlet to a open center spool valve. Make certain the liftall can breathe or there is a possibility of breaking the case.
Post A Followup
: Re: Re: Hydraulic connections
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
