Re: Re: Got the F-12 running today
Posted by Dan in Ore on April 20, 2003 at 06:41:49 from (198.81.26.239):
In Reply to: Re: Got the F-12 running today posted by F14 on April 20, 2003 at 03:18:35:
Yes it does feel great. Had to pull it, but it starts with the crank now that the rings started to seat and have some compression.
When I took the engine apart, I broke 2 pistons and had to take the pistons out of another engine. The new pistons were domed. After I got it all together, the engine wouldn't turn over for love nor money. Got discouraged and let it set for quite a while. Finally tore it back down and found the liners were .005 undersized. Put the pistons in the lathe and now they are .005 undersized also. While I had them in the lathe, I cut the dome off of them.
The governor is a little sticky and need to set the tappets. Do you know what the valve setting should be?
When I'm finished will post pics.
Dan
Post A Followup
: Re: Re: Re: Got the F-12 running today
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
