Re: Hydraulic connections
Posted by Brent on April 20, 2003 at 14:22:58 from (207.177.94.232):
In Reply to: Hydraulic connections posted by Bart on April 19, 2003 at 03:38:58:
Not exactly sure if both are outlets, but you could hook up to then to find out, or look in a service manual. You could run one outlet from the tractor to the spool valve inlet (get a 2-valve if you want to run loader arms & loader bucket) and the outlet from the spool valve would run back into the hydro tank. On my H it goes back in through the hydro drain under the tractor, not sure how your tank is plumbed since it is a live system and tank is different.
Post A Followup
: Re: Re: Hydraulic connections
