Re: Re: H head casting numbers
Posted by Ken c on April 20, 2003 at 18:51:49 from (205.188.209.141):
In Reply to: Re: H head casting numbers posted by Steven@nd on April 20, 2003 at 11:10:15:
I guess mine is low compression as the number appears to be 8776. I thought that may be the case as compression test was only in the 80 range .I plan on putting a set of rings in and thought I would rather have the higher compression head as we do pull with it. being it had the working shutters and small gas tank I thought it may be low compression.but had no numbers to check thanks to you guys for the numbers really appreciate it. ken
Post A Followup
: Re: Re: Re: H head casting numbers
