Re: Farmall H specificiations
Posted by Steven@nd on April 21, 2003 at 16:47:02 from (12.23.184.22):
In Reply to: Farmall H specificiations posted by RET on April 21, 2003 at 07:42:51:
Do NOT use Hy-Tran in the transmission/rearend. The gears will run forever when you push the clutch. Plus it will leak all over the place. 85W-140 is closer to the original type gear lube.
Hy-Tran works fine in the belly pump, just a little less pressure. 30 weight non-detergent oil is what was called for originally.
Belly pump - 6 quarts
Engine - 6 quarts oil
Radiator - about 4 gallons
Tranny/rearend - 6 gallons
Post A Followup
: Re: Re: Farmall H specificiations
