Re: Re: Re: Re: Re: SAE30 vs. Hytran Hydraulic Fluid
Posted by Steven@nd on April 21, 2003 at 16:48:25 from (12.23.184.22):
In Reply to: Re: Re: Re: Re: SAE30 vs. Hytran Hydraulic Fluid posted by RickB. on April 21, 2003 at 14:49:46:
30W is winter oil, you need straight 30 weight non-detergent.
And Hy-Tran gets PLENTY of pressure in a belly pump, I have the low pressure style in my 42 H and it lifts everything with ease.
All LIVE hydraulic systems take Hy-Tran. The only one to use SAE 30 in is the belly pumps.
Post A Followup
: Re: Re: Re: Re: Re: Re: SAE30 vs. Hytran Hydraulic Fluid
