Re: backfiring H
Posted by Charles Norwood on April 21, 2003 at 17:54:59 from (207.178.96.211):
In Reply to: backfiring H posted by J Smith on April 21, 2003 at 17:39:53:
If a cylinder isn't firing you will have a constant miss. Sounds to me like it's out of time. But, if it was running ok before you did the carb, it could be a carb problem. Someone else will have to answer your valve question, you might try adjustig them to specs (0.017 hot).
Post A Followup
: Re: Re: backfiring H
