Re: Wide front hub conversion
Posted by Hugh MacKay on April 21, 2003 at 18:47:12 from (64.228.14.79):
In Reply to: Wide front hub conversion posted by Hayne D. Matthews on April 21, 2003 at 18:15:57:
As I see it you have two options, slide the adjustable tubes into your front end and couple ty-rods where convenient. I would think they would both have to be either IH, Schwartz, etc front ends. Both the same.
Take your old bearings and proposed new wheels to a bearing store, they can match them up, with new bearings and seals. Probably cheaper to change whats necessary on front end. Also a slim chance your current wheels and bearings will fit.
If you on the other hand change the whole front end your SM will turn shorter.
Post A Followup
: Re: Re: Wide front hub conversion
