Re: 350U Wheatland Gas - too much play in steering
Posted by big fred on April 21, 2003 at 19:48:30 from (65.219.138.101):
In Reply to: 350U Wheatland Gas - too much play in steering posted by Sean in Calgary on April 21, 2003 at 08:20:46:
There is backlash adjustment in the gearbox, but I don't recall how it is supposed to work. If the play is only in the steering wheel shaft, you could probably get a good machine shop to rebuild the steering pin (part of the left steering shaft) and re-shape it. If the play is between the left and right wheels, you would need the gears re-shaped. Also check for sloppy bushings where the shafts come out of the gearbox. Sloppiness there can give you a surprising amount of play. If it comes down to replace or rebuild, you'll find those gearboxes are scarcer than hen's teeth and pretty pricey. You can use one out of a 300U, 350U or a 460U. I opted to rebuild mine.
Post A Followup
: Re: Re: 350U Wheatland Gas - too much play in steering
