Re: Farmall F-20 timing
Posted by Dave on April 22, 2003 at 02:49:51 from (216.42.122.84):
In Reply to: Farmall F-20 timing posted by Andrew on April 21, 2003 at 14:40:31:
I had to hold a short stick against the flywheel surface while my buddy cranked to clean off the gunk so the DC mark could be seen. If you don't check for compresson or look under valve cover to see that both valves are closed you have a 50-50 chance on getting it right.Spark lever should be all the way up,spark retarded.Points just starting to open.You might have to fiddle with the coupling a hole at a time to get exactly what you want.Usally this method is dead on the first time.Good luck
Post A Followup
: Re: Re: Farmall F-20 timing
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
