Re: Re: Re: switching from generator to alternator
Posted by Steve - IN on April 22, 2003 at 11:51:38 from (12.222.17.59):
In Reply to: Re: Re: switching from generator to alternator posted by Brandon on April 22, 2003 at 04:31:31:
Brandon, Since it's a Delco, let's ASSUME it's an SI setup to be wired in 2/3 fashion, and that this diagram will get you going. If know it's a Delco SI jumpered for 1 wire use, just hook into the battery from the BAT terminal on the alt. If you don't have an indicator light, use a 10 ohm 10 watt resistor between the number 1 terminal on the alternator and an ignition source to properly excite the alternator. You may see the alternator not start charging until you reach higher revs. An easy way to fix this is with a smaller pulley. Note that you will not need your regulator in this setup as the Delco is internally regulated. As I said, I'm assuming you have a Delco SI...double check that. Also please check BobM's diagrams for the complete wiring setup for the load accessories, etc.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
