Re: how hot is a 400 engine supposed to get
Posted by CNKS on April 22, 2003 at 18:28:38 from (207.178.96.214):
In Reply to: how hot is a 400 engine supposed to get posted by Bryce Andreasen (Magnum) on April 21, 2003 at 20:02:27:
If you are running it at max load in mid-summer, you will probably find that it will be on the mid-to high side of the "run" section. Keep it out of the red by shifting down a gear as suggested below. The 50-50 antifreeze raises the boiling point to above the safe temperature for your tractor, so it is strictly for freeze and corrosion protection. The pressurized cap allows you to exceed the "safe" temp for brief periods of time without losing coolant.
Post A Followup
: Re: Re: how hot is a 400 engine supposed to get
