Re: removing the deck - Farmall H
Posted by Mike ISW on April 23, 2003 at 04:27:59 from (64.12.97.13):
In Reply to: removing the deck - Farmall H posted by mike in PA on April 22, 2003 at 22:15:37:
The shifting forks and rails will come up with the deck plate. They are not holding you up. More than likely deck is hung up on the 2 dowel pins. One on each side. Some spray lube on these and careful pressure with a pry bar on each side should do the trick. Good Luck, Mike
Post A Followup
: Re: Re: removing the deck - Farmall H
