Re: Re: 544/460
Posted by Steve on April 23, 2003 at 05:29:23 from (158.106.50.3):
In Reply to: Re: 544/460 posted by Hugh MacKay on April 22, 2003 at 15:56:00:
I'm afraid you're right. I located a manual describing the TA/foot clutch adjustment and inspected the tractor. Immediately obvious is that the spring connecting the cam plates is LONG GONE. To make matters even worse [if that's possible] is that the cam plate face has been worn down and repaired with a length of bar stock that in turn has a divot worn into it. Once we have the spring I'll try setting the adjustments to the manual specs. It just gets better and better.
Post A Followup
: Re: Re: Re: 544/460
