Re: Farmall H Light Problem
Posted by Randy in NE on April 24, 2003 at 04:47:32 from (216.58.237.20):
In Reply to: Farmall H Light Problem posted by RC on April 24, 2003 at 04:29:23:
Could be a broken wire between the switch and the light fixture. Could be a bad or worn light socket. Is the bulb good. You might try switching the bulbs from one side to the other. Sometimes you have to look real close to see whether the filament in the bulb is good or not. Try running a jumper wire straight from the switch to the light. I my '50 C has about the same light bar as the H. I had to re-wire both of the lights. Used the old wire as a pull string to pull the new wire. Not much room to work in there.
Post A Followup
: Re: Re: Farmall H Light Problem
