Farmall Tractors Discussion Board
Re: live power on super M
Posted by Stan(VA). on September 14, 1999 at 04:56:59 from (207.172.109.158):
In Reply to: live power on super M posted by Robert DeWilde on September 13, 1999 at 17:54:05:
You would need the transmission and clutch housing to go with it. They used what looks like a shaft inside a sleeve up at the clutch and pressure plate to get the independent power sources. The inner shaft runs off the clutch, and the outer sleeve looks like it runs from the pressure plate (hard to see in the diagram). Then the independent drive from the outer sleeve is picked off by another shaft that runs it around the trans gears to the rear for the PTO. This shaft is turning all the time which is why the new PTO has a clutch in the housing.
Stan(VA).
Post a Followup
: Re: Re: live power on super M
