Re: Re: Re: Re: Re: Re: brake pedals on H
Posted by The Red on April 24, 2003 at 15:49:56 from (12.84.240.151):
In Reply to: Re: Re: Re: Re: Re: brake pedals on H posted by mike in PA on April 24, 2003 at 15:40:58:
Mike the purpose of the adjustment screw on the bottom was to keep the brake band in a somewhat round position in the not braking mode so the top of the band did not drag across the drum all the time while not applying brake pressure. I don't think that engineering feat made it to ths space shuttle. :)
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: brake pedals on H
