Re: Re: Re: Re: IH 1066 Plowing trouble
Posted by Paul on April 24, 2003 at 21:06:31 from (66.71.10.157):
In Reply to: Re: Re: Re: IH 1066 Plowing trouble posted by steveormary on April 24, 2003 at 20:58:13:
I agree 100% when I am running the grain drill it is in 1st or 2nd gear, it is a piece of equipment that can't be run fast, Just like a rake, you have to go slow to get all the hay (unless there is rain in the forcast). If you go fast you will miss hay and finding a hole you will make a mess. But as for things such as working ground, there is no need to go slow, the faster the better. I have worked ground that I plowed with our 1066 with 4X16 in a high gear, then I worked ground that I plowed with our 656 with 3X16 at a slow speed. Let me tell you the faster the better, it will break up the ground as it turns it over.
Post A Followup
: Re: Re: Re: Re: Re: IH 1066 Plowing trouble
