Re: After Market 90 degree Distibutor Question for an H
Posted by The Red on April 25, 2003 at 08:26:38 from (206.246.187.2):
In Reply to: After Market 90 degree Distibutor Question for an H posted by Jerry on April 25, 2003 at 07:50:56:
Jerry it doesn't matter where #1 is on the distributor.
Get #1 piston on TDC on the compression stroke. Turn on the ignition.
Turn the distributor body until the points flash, or start to open.
Turn off the ignition. Wherever that rotor is pointing will be the #1 post.
Then in a clockwise order, wire up #3, #4, #2.
I have two Ms with aftermarket Delco. #1 post is different on each one.
Post A Followup
: Re: Re: After Market 90 degree Distibutor Question for an H
