Re: Re: Farmall F-20 magneto timing-
Posted by Andrew on April 25, 2003 at 23:19:27 from (207.140.80.179):
In Reply to: Re: Farmall F-20 magneto timing- posted by Bob Kerr on April 25, 2003 at 16:47:20:
Thanks for the tip, I will try it again tomarrow, I have the timing close but not qite where it should be, I knew it would kick back if it was firing before TDC, but where it's at now, when the engine is warm it will start with just about 1/4 turn! Where I have it now, when the spark is retarded it's firing a few degrees after TDC. I still can't figure out why the mark on the flywheel doesn't line up, it comes closer to lining up when the mag retard lever is advanced... What does the E and O stand for?
Post A Followup
: Re: Re: Re: Farmall F-20 magneto timing-
