Re: M wont stay cool under load
Posted by oldsalty on April 27, 2003 at 07:47:09 from (130.76.32.20):
In Reply to: M wont stay cool under load posted by 49 Cubber! on April 26, 2003 at 19:20:22:
An easy check to try is work the tractor till
it hot, Say 200 degrees. Run your hand over the front of the radiator from side to side top and bottom. You are checking for an even temperture
of radiator. Cooler areas indictate a radiator
with crud in it. Good luck.
Post A Followup
: Re: Re: M wont stay cool under load
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
