Re: Re: farmall H clutch
Posted by Jailkeeper on April 27, 2003 at 20:43:11 from (216.174.170.19):
In Reply to: Re: farmall H clutch posted by BIG JOHN on April 27, 2003 at 16:19:14:
The shock of applying the brakes while the clutch is still engaged is what breaks the disc free. When I worked for a JD dealership, we had a 4020 that was brought in at least twice. It was used to run a pump so it was always outside. Seems the clutch wouldn't disengage due to all the years of sitting outside.
At least twice a trip around the parking lot hitting the brakes was all it needed to free up the clutch. Eventually it did have to be replaced.
Post A Followup
: Re: Re: Re: farmall H clutch
