Re: Fasthitch on C
Posted by Ernie Bob on April 27, 2003 at 21:36:49 from (198.81.26.239):
In Reply to: Fasthitch on C posted by Mark Weinheimer on April 27, 2003 at 19:37:10:
Mark,
There are three different hydraulic adjustments on the C fasthitch. Which one are you refering to? The arm on the left-rear of course raises and lowers the hitch. The left to right leveling adjustment is from the arm on the center-left side and connects to a belcrank just behind the left-rear axle housing with a 1/2" x 2" bar. The depth control or front to back adjustment is from the arm on the center-right side and a pipe style connection to the front of the hitch under the platform. I hope this helps, if need be you can e-mail me and i will take some photos and look in my manual to see if it has some details on this.
Good Luck!
Ernie Bob
Post A Followup
: Re: Re: Fasthitch on C
